9 inchs questions please help
Old 12-21-2008, 12:45 PM
ryan00z28camaro's Avatar
Default 9 inchs questions please help
hey guys im looking to but a 9 inch housing from a guy for around 500 but was curious as to what all i would need and would there be any problems putting it under my car which is not mini tubbed the housing has been narrowed 3 inchs on both sides is my main concerion all i can think i will need is
-center section with gears
-axles
if theres anything else let me know guys appreciate the help ahead of time
Old 12-21-2008, 12:47 PM
Slvr00Bird's Avatar
U-joint adapter, probably massage the tunnel to get it to fit. A rim with the correct offset (I'm not exactly sure if you'll have any clearance issues with the narrowing and stock components or what all needs to be done there).
Old 12-21-2008, 12:57 PM
thanks more info would be appreciated
Old 12-21-2008, 08:09 PM
also if i were to put this rear in what backspacing on wheels would i need to make it look right help asap planning on going to pick this rear up toomarrow morning thanks guys
Old 12-22-2008, 12:48 AM
also my car has abs and tcs what do i need to do to get around this dont ness. need them prefer to but dont have to but really dont want the lights on the guage cluster lit up?
Old 12-22-2008, 07:44 AM
anyone?
Old 12-22-2008, 10:59 AM
Jawsgear's Avatar
Easiest thing to do is not buy a diff for $500.00 that does not fit your car. For a little bit more money you can get the right housing that will work with all the ABS, TCS, is the correct width. SOunds to me like you are going to buy a headache to just save a few bucks. Not worth it!
Jeff
Old 12-22-2008, 01:50 PM
MrElectric03's Avatar
Jeff
x2, if its not set up its going to be hell to get it right. If it were narrowed 1" each side or even 3" total (1.5" per side) it wouldnt be so bad but with it narrowed that much im sure your wheel selection would be pretty limited.
I looked into trying to save money by looking for something like that before I bought my 9" but instead I bought one ready to go from Midwest, all I did was press the bearings on the axles and install was a breeze!
