3 and 4 channel Moser axles?
Old 12-22-2008, 06:48 PM
RsSean's Avatar
Default 3 and 4 channel Moser axles?
What is the difference in the 3 channel axles and the 4 channel axles?
Are they interchangable? I have some 4 channel axles and I have a 3 channel rear end will they work? I don't see the difference. Different part numbers.
Old 12-22-2008, 07:30 PM
EPP
EPP's Avatar
The 4 channel axles are machined for the reluctor rings to fit on, that is the only difference. Bob
Old 12-22-2008, 07:39 PM
RsSean's Avatar
Will they fit in my 3 channel? or will they not
Old 12-23-2008, 04:12 AM
EPP
EPP's Avatar
I've never tried it but I don't see why they would not work. Bob
Old 12-23-2008, 09:52 AM
wht01ws6ta's Avatar
And you shouldn't have to worry about your ABS because your speed sensor is in the pumpkin, everything should still work fine. 4 channel speed sensors are on the ends of the axles but your 3 channel rear won't know the difference.
