2.73's to 3.73's
Old 01-05-2009, 03:51 AM
green28's Avatar
Default 2.73's to 3.73's
I plan on getting some 3.73's to replace my 2.73's. Just have a few questions that I couldn't find answers to in the stickys. I know I've got the 2 series carrier. On speed inc's website it says that the Richmond gears are thick gears to replace the 2.73's and the Motives just say they are for the 2 series carrier but also list a ring spacer for sale to use with the 2.73 carriers. Am I forced to go with the Richmonds if I want to avoid using a ring spacer or am I reading something wrong on the site, ie. does Motive also offer a thick gear.
I'm assuming the master install kit for both brands would include everything I need to do the swap. Part of the reason I'm switching gears is because I noticed the car has developed a rear pinon seal leak, so figured I might as well throw a gear in there while getting the leak fixed.
Last question for now, would I have to get the car tuned for the gear change? Does it just adjust the speedo or do the shift points also need adjusted? I'd get it done eventually, but the closest tuner is atleast an hour and 15 mins away, so I wouldn't be able to get it done right away. Just want to know that I'd be fine with doing the swap without the tune.
I know I'm a gear swap noob, but just couldn't fine much on the 2.73 to 3.73 other than people saying that its worth it.
Old 01-05-2009, 08:57 AM
FirstYrLS1Z's Avatar
Summit shows a Motive 3.73 set for a 2 series carrier.Since it's a different P/N from their 3.73 for a 3 series carrier,you would not need a spacer.
Speedo should be reprogrammed.
Fixing a leaking pinion seal can be easily accomplished without having to go into the rearend.
Old 01-05-2009, 09:00 AM
Slvr00Bird's Avatar
Go Motive gears and yes, you'll need a tune.
Old 01-05-2009, 09:03 AM
MadMike96's Avatar
Yeah motive does have such things, if you get on orielly auto parts .com you can find the gears on there. Their high tho
Old 01-05-2009, 10:41 AM
koolaid_kid's Avatar
You will certainly want a thick gear. The spacer is used to make a series 3 gear fit in a series 2 carrier; avoid it like the plague. BTW, IIRC Strange also makes a thick 3.73 gear. I run their 3.42 in my series 2 carrier.
Both install kits will work; Ratech also makes one.
You will need a transmission tune in your PCM, which is fairly minor. The PCM will be confused about when/where to shift until you get one.
Old 01-05-2009, 12:02 PM
MattIROC's Avatar
I had my old tuner recalibrate the gears to 3.73's and he changed a few things in the tranny. I picked up .7 in the 1/4 going from 2.73's to 3.73's, but the temp was also 20 degrees cooler vs the last time I took it to the track. You'll love them. I went with the Motive 2 series, and I didn't buy the Master Install Kit. I did pick up a bottle of posi additive, but told it wasn't required but I bought it anyways, along with 75w90 Mobil 1 Gear oil. This was in my 98 TA btw.
Old 01-06-2009, 01:33 AM
green28's Avatar
Ok thanks guys. The whole thick gear thing on their site had me confused. I think I'll go with the Motive 2 series and get the install kit as well. I'd be happy with picking up 2 or 3 tenths. I know my brothers 3.23 car just feels like it pulls harder with less mods, even though mine is 4 tenths quicker at the track.
Old 01-06-2009, 01:47 AM
jetlag's Avatar
Buy from www.ls1speed.com A great sponsor with quick and free shipping.
Old 01-06-2009, 01:24 PM
sasquatch's Avatar
I have a 2 series carrier and went with Motive 3.42's from Jawsgear. They are a sponsor here and I got them within 3 days of the order along with the Masterkit. Give Jeff a call and he'll hook you up.
Old 01-09-2009, 01:38 PM
99problemz's Avatar
Could somebody post a link to that? or the part number for those 3.73 gears for a 2 series carrier?
may i ask why?
Old 01-09-2009, 02:03 PM
MattIROC's Avatar
Here's the same ones I bought...
http://store.summitracing.com/partde...5&autoview=sku
I paid about $10 less for it over a year ago, and a local speed shop special ordered it for me so no shipping cost.
Old 01-12-2009, 04:19 AM
green28's Avatar
Well I got the MOT75373X with the install kit. That should be all I need to make the switch from 2.73's to 3.73's correct? Other than a tune of course. BTW, how much faster will I rack up the miles with the 3.73's on the stock gear tune? And is there much of a "break in" period for new gears?
Old 01-12-2009, 11:06 AM
MattIROC's Avatar
Gear oil, and if you want but not required, posi additive. You don't really need a tune, you just need the tranny tune and the rear ratio changed. I went about 2 weeks before I was able to meet up with my tuner, and I racked an extra 400 miles on the OD, and I probably drove 400 miles total during that 2 week period. I went 250 miles before I started beating on them. Some go to 500 I believe. I would go at least 250 miles though.
Old 01-14-2009, 06:05 PM
todddchi's Avatar
One can save a lot of money and energy just swapping in a 3.42 axle assembly from a stick car. More heavy lifting but less setup risk and cheaper.
For street use you'll be hard pressed to notice the difference between 3.42's and 3.73's. 3.42's will give you enough power to be traction limited.
Proper tune is critical regardless. It is not an option. Diablosport Predators can do a fine job with some custom tune support tweaking. I would not use a Hypertech.
Plan on losing 2-3mpg. Don't believe people who say it makes no difference. The loss of range per tank annoyed me more than the loss of mileage.
Old 01-14-2009, 06:34 PM
Sunset'01Z's Avatar
you should just fix the leak and get a stall converter. i wish i had kept my 2.73s
Quick Reply: 2.73's to 3.73's
