leakin in the rear
Old 01-13-2009, 11:15 AM
gyrene2003's Avatar
Default leakin in the rear
Ok so alittle over a year ago, i installed a set of motive 3.90s in the ***, then i deployed. Now im back, and i notice the rear-end has asubstantial drip coming from what looks like the u-joint where it meets the housing. Im just wondering how hard it is to fix this, should i be worried about a more serious problem. just hopin this is an easy fix and maybe im being ****, but whatever, cuase im doin a 4000 stall shortly and then ill be at the track later with the Mickeys, so i wanne nip this in the butt. thanx fellas
Old 01-13-2009, 07:01 PM
gyrene2003's Avatar
Anybody got anything for me.
Old 01-13-2009, 08:12 PM
johnson73801's Avatar
is it actually from the ujoint flange or is it from the pinion seal?...also if you didnt replace the seal behind the flange theyll leak every time.
Old 01-14-2009, 10:45 AM
gyrene2003's Avatar
Alright man, thanx alot. I will check it out with my biddy this weekend.
