th350 and th400 same length driveshaft? - LS1TECH
Thread Tools Search this Thread
Old 01-22-2009, 08:46 PM   #1
Default th350 and th400 same length driveshaft?
Someone I know has a driveshaft to mate a 9 inch to a th350, and I wanted to buy it to put in my th400 9" car. Same length and splines, or different?
jermzz is offline   Reply With Quote
Old 01-22-2009, 09:48 PM   #2
Might be, might not be. Why don't you measure it?
th400's come with 32 spline output shafts most common with 4" tail housings.
th400's also come with 27 spline output shafts and long tail housings.
th350's come only in 27 spline output shafts, but they also have a long and short tail housing.
A lot of variations to just guess at right?
Measure everything and go from there, no one on this website can give you a yes or no answer.
9000th01ss is offline   Reply With Quote
Old 01-22-2009, 10:15 PM   #3
TJ
same length will depend on short tail or long tail in either version, plus the fact there are long and short type yokes as well.
a vague answer... prolly not.
the th400 uses a different yoke alltogether.
if you ran a short tail 350, chances are you can get the driveshaft shortened.(cheaper of the two)
worst case, if you have a th350 long tail and a 400 short tail, youll need a new tube.
TJ is offline   Reply With Quote
Old 01-22-2009, 10:18 PM   #4
tillery's Avatar
Not the same. A 400 yoke is diff spline and the case is overall diff.
tillery is offline   Reply With Quote
Old 01-22-2009, 10:30 PM   #5
Quote:
Some th400's came with 27 spline just like the th350.
If the driveshaft is for a short th400 and a short th350 the yoke needs to be changed. All short th400's have 32 spline outputs.
Long th400's have both 27 and 32 spline outputs.
I don't understand the guessing game going on here, measure the damn thing, thats the answer.
Old 01-22-2009, 11:36 PM   #6
well i dont have the th400 yet. i have a t56 my friend is buying it off me and the th400 is being shipped from a different state. lol
i wanna get all the parts so I can just throw it together, but it looks like i'll just have one made I guess for 9" to th400....
Old 01-23-2009, 05:41 PM   #7
TJ
length will also depend on if you are using an aftermaket yoke on the rearend, or the stocker.
couple different sizes there too.
Related Topics
Thread Thread Starter Forum Replies Last Post
driveshaft length questions fastlt1 Automatic Transmission 9 01-31-2017 06:44 PM
Driveshaft length: th400-9in KevsfastZ Gears & Axles 2 08-05-2010 03:27 PM
lsx-foxbody driveshaft length questions Spoolinsteve Conversions & Hybrids 5 02-28-2010 11:12 PM
th350,th400 length difference azzsmasher69 Automatic Transmission 1 06-09-2006 05:58 PM
length of driveshaft with th400 and 9 inch Frans96SS Automatic Transmission 5 12-05-2004 11:08 PM
Tags
400, 4th, 9, driveshaft, gen, gm, lenghts, length, long, shaft, short, swap, th350, th400, yoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
