ABS 3 Channel Sensor Help!!
I have a 2001 Z28 and just dropped the rear end in hopes of replacing it with a new 9 in ford custom built rear end. My car is equipped with the 3 channel ABS sensor on top of the stock housing. Here are my questions... How do I incorporate a reluctor ring in the new rear end assembly?? Is the number of teeth and diameter critical or will any pulse rate to wheel speed work?? Do they sell reluctor rings for 9 in ford assemblies?? If anyone has any info or suggestions it would be greatly appreciated!! Thanks in advance!!
Here you go.....Eric is a good guy to deal with and can answer any questions you might have. Check out the 8th line down under Specs.
http://www.midwestchassis.com/fabd9specs.html
