quick torsen question
Old 02-10-2009, 05:56 PM
ElkySS's Avatar
Default quick torsen question
which way does the paddle go in? i lost track after i pulled it out. when installed in the car does the slot point down or up?
Old 02-10-2009, 06:13 PM
nemss1's Avatar
not really sure exactly what your talking about when u say slot. ive only had mine apart once and what i do know is the paddle has a bolt hole and the hole needs to line up with the retainer bolt
Old 02-10-2009, 06:27 PM
ElkySS's Avatar
theres 2 ways it can go in idk if its upside down or not. theres a slot that looks like fluid is supposed to go through and i cant tell if it points up or down. it will fit either way
Old 02-10-2009, 06:31 PM
nemss1's Avatar
man, i dont know then. i need to research this too then and make sure i re-installed mine the right way. ill let u know if i find anything
Old 02-10-2009, 08:53 PM
9000th01ss's Avatar
I always mark them and put them back according to the marks.
If I did lose track of it I would put it facing so it scoops oil up.
I don't really think it matters.
Old 02-11-2009, 12:01 AM
01ssreda4's Avatar
the slotted curve goes downward. with the wider ungrooved side at the top.
Old 02-11-2009, 12:08 AM
01ssreda4's Avatar
Old 02-11-2009, 12:18 AM
ElkySS's Avatar
****. i put it in the wrong way. does anyone know what will happen? or why it goes downward?
Old 02-11-2009, 07:39 PM
nemss1's Avatar
thanx for the info
