1310 or 1350 pinion yoke?
Old 02-23-2009, 01:08 PM
stevens's Avatar
Default 1310 or 1350 pinion yoke?
so im trying to order a moser 12 bolt rear, and i dont know what pinion yoke my car takes.
its a 97 camaro ss m6
thanks
Old 02-23-2009, 02:20 PM
LS1>girlfriend's Avatar
get a 1350. its bigger and can handle more torque. only thing you'll need is a 1310/1350 conversion yoke, you can pick one up at advance, autozone etc. it probably wouldnt be a bad time to change it anyway.
Old 02-23-2009, 02:25 PM
stevens's Avatar
ok does the conversionyoke just bolt in between the yoke and the drive shaft or do i have to weld it?
Old 02-23-2009, 03:23 PM
jmm98LS1's Avatar
You have to remove the factory rear u-joint on your drive shaft and replace it with the conversion u-joint.
Old 02-24-2009, 08:30 PM
03 BUSA's Avatar
If you are getting a new rear I would spend the extra $300 for a strange Chomoly d shaft with the 1350 setup and be done.
Old 02-25-2009, 11:05 AM
Jawsgear's Avatar
Conversion ujoints are simple. I would stay away for the Autozone/Napa Ujoints that are made overseas though. Go with a Spicer Ujoint if you can, they are better quality and tend to last a lot longer.
Jeff
Quick Reply: 1310 or 1350 pinion yoke?
