Ls1 aftermarket driveshaft?
I have seen them all over Ebay or on the "For Sale" forums here. If you want to buy new Summit sells the Inland Empire's. I would look into a used one before I coughed up the money and bought new. Before installing a used one I would be sure it's balanced before putting it on.
I've got a PST 3.5" aluminum driveshaft from Exotic Performance Plus and it's held up great to my high RPM clutch dumps and track abuse. I'm not making insane power, but I run consistent 1.6 60's on 10.5 ET Streets launching from about 5000 RPM.
It comes with a lifetime warranty, so I see no reason to spend more money than that unless you're making crazy power or looking for the lightweight of the chromoly.
I'm in the same boat as nastyiroc and need a replacement OEM driveshaft. I don't want to buy a used one (already been burned on that one) and I've already broken a stocker aluminum one. I'm not sure if I have enough room for a 3.5" due to DS loop and exhaust. Any good way to see if there is enough room for a 3.5" diameter DS? And are there any other options out there that can deal with a little more abuse than OEM? (yes I know the 10 bolt could go at any second but I don't want to spend 4k on a complete setup right now)
LS1Tech Sponsor
http://shop.brutespeed.com/PST-35-In...Driveshaft.htm
Check out the above links. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
That's great guys, but what your trying to sell me is a 3.5" diameter driveshaft, and as I've already stated, I'm not sure I have enough room for that between the exhaust and the driveshaft loop. If you guys know of a good way for me to ensure that it will fit and not have any interference problems than I might be game. But I sure as hell don't want to waste 300-400 on something I can't use. Don't get me wrong I'm all for an aluminum ds, because I think it fits my applications best.
Thanks,
Brad
Thanks,
Brad
I've heard good things about chromemoly for high power applications. But I would like to stick with aluminum since I will be doing a mix of both drag racing and corner carving (road atlanta). That and I doubt I will ever be pushing more than 400 to the wheels. Thanks for the info!
Thanks,
Brad
Thanks,
Brad
