Should the breather tube on differential leak?
I was wondering is it normal for the breather tube on the top of the stock 10 bolt differential to leak?. I never knew it existed until I checked my repair manual..but I have a major leak and need to know can it be replaced or could I put some rtv silicone on it?
Kleeborp the Moderator™
My 10-bolt breather tube always had gunk around it - when I went to run a breather for my 12-bolt, I used some brass fittings, a rubber hose, and a small breather tube at the top that is mounted to the frame above the housing. I've had no leaks out of it to date.
