removing 10-bolt
Old 03-11-2009, 09:46 PM
green28's Avatar
Default removing 10-bolt
I'm gonna pull out my 10-bolt tomorrow night, are there any quick tips or tricks I need to worry about? I guess the only thing I'm concerned about is not messing up the brake lines, ie. getting them out of the way to drop the rear-end.
Old 03-11-2009, 09:49 PM
jetlag's Avatar
It's easy... I removed my 10-bolt in about an hour by myself.
2 LCA bolts
2 torque arm bolts
2 shock bolts
4 caliper bolts
2 sway bar bolts (I leave it attached then remove the whole thing later)
Pop off ebrake lines
Leave a jack under the diff and when done just lower it and pull out from under the car. Unless you have a small jack, then it might be hard to balance.
Old 03-11-2009, 10:00 PM
IronOutlaw's Avatar
Just be careful with the brake lines.
Just like jetlag said its easy as pie.
I removed mine in two hours on jackstands and walmart wrenches.
Old 03-11-2009, 10:23 PM
green28's Avatar
Nice, I have a full size jack. And it's supposed to be a high of about 28 degrees out tomorrow so hopefully it won't take long to pull it out.
Old 03-11-2009, 10:36 PM
Z28LS1camaroguy's Avatar
u replacing it with a 12 bolt or 9"??? or you taking it out to paint???
Old 03-11-2009, 10:46 PM
Jefro6996's Avatar
Ya it took me about an hour also. not bad at all. but it is a lot easier to put it back in with someone helping you
Old 03-11-2009, 11:07 PM
HavATampa's Avatar
Lots of torque is the easiest way to remove it.
http://www.ebaumsworld.com/video/watch/41789
Another way to get it done:
https://ls1tech.com/forums/showthrea...ferrerid=13535
Old 03-12-2009, 09:29 AM
green28's Avatar
Actually just pulling it out to replace the 2.73's with 3.73's. But also replacing getting some LCA's, LCA relocation brackets and a new PHB. Figured I'd just pull the whole thing out to make the gear swap easier since I don't have access to a lift.
