9" Almost In
9" Almost In
Well, I just spent almost hours of grunting, busting up my hands, tearing my jeans and bruising my knees putting my new 9" into my Trans Am. After all of that work, my drivesaft doesn't match the new rear. I'm wondering, can I just swap out end caps on the the u-joint for smaller ones? And how do I go about finding the right size?
Also, how much gear oil do I put in the rear? Cause I put about 1.5 quarts in and it didn't even look any was in there (flashlight in the fill plug). I also just realized that one of the quarts I put in said "LS" on the bottle. I'm assuming that means Limited Slip, which my rear is not (locker). Does it really make a difference (it's the same weight...75W90)?
I can't remember how much I put...3-3.5 maybe. I used some heavy oil...85w140. No problems..
Are you trying to use the stock driveshaft? You will need to get a 1350 u-joint conversion kit from NAPA.
Also, you will most likely have some vibration problems and need a driveshaft that is 1" longer.
It takes a Napa 447 u joint to make a 1350 yoke work with your stock driveshaft. Bob
