Posi unit broke, gears are fine, Can I put a spool in it for now, until I buy a 9"?
Just broke the posi unit in my 10 bolt, but the gears are fine. Can I just put a spool in it for now, until I purchase a fab 9" from Midwest Chassis? Where can I get a cheap spool at? Thanks!
LS1Tech Premium Sponsor
mini-spool will definetly get the job done. you have to be carefull of what you buy because the spools wont necessarily fit any diff unit. If you are just looking to get by for a while until the new rearend is in your hands, i would just have someone weld the side gears to the carrier and call it a day. ever heard of a "lincoln locker"? not like you are gonna hurt the posi anymore...
you have 28 spline axles. probably a torsen diff way to difficult to weld successfully. so you'll need an open carrier to use a mini spool. or do as suggested and weld up an open carrier. either way you need a 28 spline 88 and up 3:23 open carrier. call your junkyard ask for a carrier out of a 90 s10. they sell them for like 49.00 here and you get a set of gears usally 3:73s.
