Slip Additive in Moser 9Inch???
My rear end whines too much on the highway and I was wondering if I could put a bottle of GM's limited slip additive to help the whine? I have a bottle sitting around.
It's not the diff making the whine. It's more than likely a bad gear install. What ratio you running, and did you have a shop re-verify that the gear pattern was good?
Motive 4.11's in a moser 9 inch with pinion angle at -2...Has a tru track and the shop has looked over the gear pattern and they said that it was fine..But the whine sux! So adding additive wouldnt help?
