different driveshaft?
i just picked up a moser 9 inch do i need to get a longer driveshaft to install this or will it directly bolt in? sorry if this questions been asked before i searched couldnt find it.
You can use a Napa 447 conversion u joint to use your stock driveshaft, and for most people this will be sufficient. The driveshaft will be one inch shorter than what it really should be, and for most people this does not cause a problem. It has caused a vibration for some and the only way to get rid of the vibration was to get a one inch longer driveshaft. Bob
