10bolt help
Old 04-05-2009, 11:18 AM
gnictry's Avatar
Question 10bolt help
OKay so I messed up my spider gears in my rear fri nite at the track.
I want to put a spool in for now...I dont drive it everyday but it isnt just a weekender either. I understand that it will be harder on low mph turns and parking.
I dont understand what I need (got 3.73)
whats the differencde between mini or full spool?
I dont want to have to re-shim which means I should get a mini -right?
Also heard minis require an open diff-do I have that? How do I tell?
I am looking to get
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
is this right?
when looking at my rear I can see the spider gears does this mean its open?
Old 04-05-2009, 11:38 AM
MikeG's Avatar
Well, you've got a trans am so you don't have an open differential. You'd have to get one of those too. The eBay link is the right mini spool though. I don't believe anybody makes a full spool for our rears.
Old 04-05-2009, 02:54 PM
the hulk's Avatar
Default help`
just replaced all the gutts in my 10 bolt an now it wines like crazy~~ think the guy shimmed it wrong??? gimme a reply" no hurry jus a weekend car
Old 04-05-2009, 03:20 PM
gnictry's Avatar
were would i get an open diff? How can you tell?
Old 04-05-2009, 03:54 PM
gnictry's Avatar
should I get new internal spider gears or do I have to get a whole new unit?
Old 04-06-2009, 10:51 AM
gnictry's Avatar
okay ebay link seller said a diff would be another 100 so 200 plus shimming and shipping for a spool
or detroit locker for 540 plus shim and ship or what else?
Suggestions needed asap would like to order all neccesssary parts tonight...
Old 04-06-2009, 12:48 PM
gnictry's Avatar
i may put a auburn in for time being while i build a used ford 9in out of a camaro
I am not sure on internals do no i need adapters for my rims to work and weld brackets on it.
also was told it does not have abs- doesnt that mean its a 3series? How does it drive on the street?
can i use my stock shocks and springs and drive shaft?
I was also told I will need brake conversion-which one?
Do i need lca or sway bars?
list of required parts or an install rewrite up would be great!
Old 04-06-2009, 03:39 PM
gnictry's Avatar
to the top
Old 04-06-2009, 06:03 PM
gnictry's Avatar
any1???
Old 04-08-2009, 03:22 PM
gnictry's Avatar
is anyone selling adj lca?
rear sway bar?-aftermarket
Old 04-08-2009, 05:53 PM
sroach20's Avatar
i just picked up a brand new eaton for $400.
Old 04-11-2009, 12:05 PM
gnictry's Avatar
so suppossed to be getting used locker for 260 ...any one got lca?
