2.73-3.42
2.73-3.42
my car has a stock 10 bolt with 2.73's in it and is a daily driver. i want to get some better track times. if i put in a 3.42 rear with drag radials just for the track will this mess with anything computer wise?
i can easily switch between rears just for the track cause i need the car to dd, just wanna know if runnin it with higher gears w/o re-calibrating the speedo will make the car run bad? thanks.
ill be changing the whole rearend, a friend has a spare. ill be running drag radials so im planning on switching the whole rearend for the track only. then changing it back to the 2.73 rearend for daily driving.
damn good luck man. thats an awful lot of work to go through
I went from 2.73 to 4.11, and never had a problem with shift points or bouncing off the rev limiter. I also went from 4.11 to 3.42 and no problems eather. And i have not had the computer tuned.
It will be fine to change the gear, the spedo will just be off a little...
haha. only takes like 25-30 mins to pull a rear out of these cars. not that many bolts.
Going from a 2.73 rear end to a 3.23 rear end I was hitting the rev limiter, so its all in the tune. With regards to the rear end swap. I guarantee you will be rethinking that swapping rear ends back and forth. That is a lot of work, I've done it a couple of times and really don't care to do it again.
Not going to be doing that again any time soon. My back still hurts.
HE SPEAKS THE TRUTH. I just finished swapping in a 3.42 rear for my 2.73. VERY happy with the results. BUT...I don't know if my unibody has flexed or what, but it was a BITCH to get the rear suspension reinstalled.
ya i hear ya man. ive done a few rearends for buddies and whatnot. i dont mind the work. kinda like it actually. what kind of tuning did u do for the new gears if any?
None yet. I plan on it though, the GPS is my speedometer for now. I would definitely like to have the shift points redone, at least so it'll hold 1st for a bit longer. Don't know much about these things. As soon as I find a good tuner somewhere pretty close to Central VA, its off to the races.
You'll be happy with the results though. 2.73's blow.
