Factory Freak 10 bolt guys come in!
Ok first of all let me throw this caveat out there lol, I know that 10 bolts suck, I know they break on stock hp with street tires etc etc so I do know the risks .
I am trying to stretch the budget a little bit this summer and trying to do the top end, full bolt ons etc and then 9" later this summer or early next spring before I even drive the car out of storage. All and all my car should see hopefully 450+rwhp through the stock 10 bolt and stock 3.42's so my question is how much did you throw at your 10 bolt before it finally went?
just my oppinion: with 450/standard/tires,I think you will be lucky to get 5-10 lanches
(if it lives beyound the first)
but I am in no place to say as I am a4/stalled
just my .02' Johnny
just my .02' Johnny
I'm pushing about 410 rwhp with an M6 car. I never got a chance to "officially" track run, but I do street race. My 3.42 10 bolt lasted all of about 4 good launches before shelling out. Good news is that it DID get me home before completely giving up the ghost. hahaha
There have been a few knowledgable guys here who have said "build your car from the chassis up". I'm kinda leaning toward that school of thought now.
I have been running 430rwhp & 396rwtq on drag radials for the past year with ZERO problems. Prior to that 380rwhp 370rwtq for 5 years.. I have run 3.90's, 4.10's, 4.30's in the 10bolt. The only set that "broke" where the 4.10's... chipped a couple teeth on the ring gear which I blame on a poor setup by a local shop. I had the 4.30's and then the 3.90's installed by a sponser, Futral MotorSports and have had no problems.
I have made 8 passes running at 565rwhp 585rwtq with a best of 11.13 @ 130 on a 1.84 60'.... this was with a 125shot at full weight on a 275/40 17" Nitto DR
The 10bolt will hold up well if you are a "Smooth" driver......
I do plan on upgrading the rearend
I have 400rwhp with plenty of drag launches with street tires and M6. I think if I went to slicks I might be pushing my luck. But right now I have a 9in sitting in the garage waiting to go in so my 10 bolt will never break
Haha well I did have M/T ET Street DR's on it about a year ago for a couple of bone stock passes and both the clutch and rear seemed to be begging for mercy so I swapped the tires back lol....I am at least going to leave the 10 bolt on there for the big dyno number
i cut 1.45s on mine but i was A4, i know a guy with a 6 speed bolton car cutting 1.6's on slicks and know several other buddies that have cut 1.4s. Between probley 5or 6 of us none have broken a rear end. the 10 bolt isnt as bad as its thought to be you just have to know how to treat it and set it up.
With BFGs DRs I tried launchin with the bottle a bunch of times ON THE STREET, not on a prepped track, and that is somewhere around 450hp launchin at 2300-2700rpm, ALOT!!! and no whin, grind, issues, but I am putting 4.10s in now, and taking my time to shim it right, I am in the same boat, HOPING that the rear holds up till I can afford a Moser 9, or maybe a dana 60.. which ever
so....factory freak guys....does the TA 10 bolt girdle cover actually help? or will it just be a 1 time assist to get home if that? haha. looking to be about 400rwhp after cam only install *bolt ons already*, saving for 9" anyway, just prefer not to have her puke on me while going 3 digits on the freeway.
