LOUD 9" Rear-end....Help
Old 04-30-2009, 10:21 AM
Haans249's Avatar
Default LOUD 9" Rear-end....Help
I have a Ford 9" with a aluminum Strange center section, Detroit TruTrac, 3.70 gears, and moser 30 spline axles. I have tubular LCA, Panhard bar, panhard bar relocation kit, BMR torque arm connected to a UMI torque arm relocation transmission crossmember. All items are connect to the car via poly bushings. Car is a 2001 WS6. I have one major problem though, the rear end is AMAZINGLY LOUD. Cruising at 45 - 80 mph, its so loud that I can't even hear the exhaust of my 427 motor. I have to basically yell to have a conversation in the car, and sometimes its so loud that it literally hurts my ears. I have a few questions regarding this:
1) IS THIS NORMAL?!
2) It ONLY makes the noise when rear is loaded (light throttle etc). Off throttle (coasting) it is as quiet as a sleeping baby.
3) During the loudest noises, I can feel a HEAVY vibration in my shifter handle and feel a heavy vibration on the tunnel over the rear between the back seats.
4) I took it back to the place I got it (Drivetrain Solutions) and had him check the backlash, he said he "fixed" it, but it sounded exactly the same - LOUD AS HELL. He said that he put in "race" gears and that a softer gear would quiet it down a little more, whats the difference? And where would I get "softer" 3.70 gears?
5) Now what the hell do I do?! The rear makes my car COMPLETELY terrible to drive and its my daily driver.
Thanks for any help!
Old 04-30-2009, 10:48 AM
Nightrydass's Avatar
1) IS THIS NORMAL?!
i think he is blowing smoke up ur ***; I.E, he has no idea what he is doing/talking about and thnks ur an idiot. I have never heard of "softer gears"; what does he want you to do, use Playdough?
I would take it somewhere else and have THEM check the backlash.
Old 04-30-2009, 11:24 AM
wrd1972's Avatar
1) IS THIS NORMAL?!
1. No its NOT normal.
2. Gears are not set right.
3. Again possibly bad gear setup or even a driveshaft out of balance.
4. Softer gears are more durable but are a bit louder. Loud as you claim and them being called "fixed" is BS.
5. Write the current gears off and have someone who knows what they are doing make it right and run nearly silent if not totally silent.
Gears are a funny thing. Mine were set up by someone else and they were quiet at first then started screaming like you descibed. I ended up pulling it and adding .008 pinion shim IIRC and they are nearly dead silent. It is not uncommon to have to reset the gears a couple of times to get them quiet. Luckily the 9" is very easy to do.
Old 04-30-2009, 12:01 PM
ShevrolayZ28's Avatar
Take it back to him again. Scott knows his stuff...
Maybe we on here, the uninformed, should hold off on such harsh criticism unless we are sure we know what the hell it is we are talking about. Just a thought.
Old 04-30-2009, 03:39 PM
wrd1972's Avatar
When the installer told the OP that it was fixed, and the OP states that it is now as loud as was before the installer reset the gears, here lies the problem. Fixed means fixed or at the least marginally to significantly more quiet than before as it relates to the gears.
What else do you really need to be informed about? He was again told it was fixed.
Old 05-01-2009, 12:16 AM
Sorry for the confusion, I was referring to the post ahead of yours.
Haans249, are you sure there isn't another problem? If you are running a stock length drive shaft, it is probably too short. This could cause some noise and vibration, not really like gear noise, though....
With everything assembled and the suspension loaded, see how much yoke is sticking out of the tail shaft of the trans. There should be a solid coupling there and the yoke should be pulled out no more than an inch.
Double check to make sure nothing is making contact with the bottom of the car.
If it were mine and I lived close to the shop (DLS is in Michigan IIRC), I'd bring in the whole car...can you do that?
Old 05-01-2009, 09:39 PM
Haans249's Avatar
I have done all of that. The driveshaft is a custom length 3.5" PST driveshaft for the 9". He did mention that he thought the yolk was a bit long, but that it really wasn't of much concern since it sat far enough forward.
Other than that, I did take it back to him and thats when he said he fixed the noise. He did say he adjusted the backlash etc... but it didn't do anything, it was still super loud and still is to this day. He has done all of the rearend work on my car from installing it and readjusting the backlash.
I'm not saying that he is a liar, or that he thinks I'm an idiot etc... he is a really awesome guy, and I really enjoyed working with him. Hell, I even paid him more than he was asking out of good faith. I'm just to the point now that I can't stand the noise any longer and wanted to check and see if its normal or not. I'm hearing that it shouldn't be like that.
Old 05-01-2009, 09:48 PM
Haans249's Avatar
Thats a relief, let me tell ya.
My initial thought
Driveshaft is a possibility, but the vibration when i say "heavy" is like a cell phone vibrating on horse steroids
He never replaced the gears, he just reset the backlash. I thought about getting gears replaced with "softer" gears as he suggested, but I suppose now that's not quite right.
I'm thinking of taking it to Driveline Solutions here (DLS) in Detroit.
Do your gears REALLY run nearly dead silent??! Even after your rear gets nice and "warmed" up? If I could get my rear to run nearly dead silent, I would probably **** my pants because my car would then be MUCH more enjoyable to drive! Remember, I have an ALUMINUM center section to save on weight, so is it possible that its just always going to be shifting? I'm not running more than 650-680 fwhp through it, but I do have a 6-speed and they're hard on rears...
Please read response in your quote.
Old 05-01-2009, 10:24 PM
Hmmm....I'd have him try changing the lash again. If that doesn't do it, maybe it's time to consider installing a different set of gears. From what I understand, the race gears will be softer metal and less prone to breakage, but they will also wear faster. I have no clue if they'd be more quiet as a rule....
Old 05-01-2009, 11:17 PM
C Murda's Avatar
my moser rear is NOISY AS HELL! that damn gear whine kills the pleasure of driving it on the highway. dunno if yu said you had a moser or not but i read somewhere on hear that the center sections are set up at moser just to get them shipped out and that to be truly satisfied you should have it set up at a professioal drivetrain/axle shop s there will be no noise. i have 4.11s and my god i wish i brought it to someone to re-set it up. i just assembled my rear and drove. big mistake
Old 05-02-2009, 05:11 PM
Haans249's Avatar
My rear has a strange aluminum center section. It was completely assembled and built by Scott at Drivetrain Solutions.
Old 05-03-2009, 07:44 AM
wrd1972's Avatar
Yes my gears are nearly silent. I know what screamers sound like and I have always been able to take screamers and make them near silent assuming they are rather new. IMHO its kind of hard to miss the backlash on 9" gears, its the pinion depth thats more of a PITA.
Pull the chunk out and snap some pics of the patterna. Bet they look like poo.
Old 05-05-2009, 08:19 AM
Billiumss's Avatar
Exclamation
1) IS THIS NORMAL?!
Looks like Scott is up to his old tricks.
I had the same noise problems, I got screwed by him over a year ago and I got mine fixed locally, cost me $600 to get rid of the noise, new gear set, new bearings and install. The local guy checked everything before he tore it down and it was way out of spec.
Old 05-05-2009, 08:44 AM
Blown427conv's Avatar
The gears are not set up properly. I had the same problem on a tubbed 97 Z28 till I went in and re-set the pinion depth. He might have over or under torgued the pinion nut. You need to take it some where else. Really need to know what you are diong inside of there.
Old 05-07-2009, 12:46 PM
Haans249's Avatar
That makes me feel good, yay. I suppose I'll be calling DriveTrain Specialists before I move to Texas.
Old 05-07-2009, 09:33 PM
Jawsgear's Avatar
LOL, we fixed more than one of those diffs set up by said builder.
Jeff
Old 05-07-2009, 10:38 PM
Haans249's Avatar
Jeff
Glad its funny, i'll laugh once its fixed.
Old 05-09-2009, 01:19 PM
Haans249's Avatar
Took it to DTS, they said they didn't want to mess with it as they can't guarantee quieting it down. Anyone in the southeast MI area that will take a look? I will post up video of how loud it is.
Old 05-10-2009, 07:37 PM
Haans249's Avatar
Here is the video.....so loud it drone's out my exhaust hahaha.
http://www.youtube.com/watch?v=GX63NQsG1mg
Old 05-11-2009, 11:14 AM
Chrome355z's Avatar
Holy **** dude.
Quick Reply: LOUD 9" Rear-end....Help
