replacing pinon seal help!! - LS1TECH
Thread Tools Search this Thread
Old 05-06-2009, 07:35 PM   #1
Bad_tx_Z28's Avatar
Exclamation replacing pinon seal help!!
im in the middle of replacing the pinion seal on my 94 z. It has the stock 10 bolt under it. I have the yoke off and ready to remove the pinion seal, but the bastard wont move! any tips or tricks?? I need help asap! thanks guys!
Bad_tx_Z28 is offline   Reply With Quote
Old 05-06-2009, 07:37 PM   #2
LS1Aggie's Avatar
if its the factory seal its just in there really good. Use a seal puller or a big prybar to remove it. Be careful to not bang up your pinion though. It took some muscle to get the seal out when I rebuilt my rear end.
LS1Aggie is offline   Reply With Quote
Old 05-06-2009, 09:44 PM   #3
Yup, and be sure to use a new crush collar and set the bearing preload.
DaddySS is offline   Reply With Quote
Old 05-06-2009, 10:28 PM   #4
Bad_tx_Z28's Avatar
finally got the bitch out! damn...nothing like 15 years of grime and road junk and a stubborn seal to ruin your day!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
