Is 4 qt. lube too much for MWC FAB 9???
Old 05-11-2009, 07:52 PM
RENE'S RAGE's Avatar
Default Is 4 qt. lube too much for MWC FAB 9???
Got a MWC FAB 9, narrow 3" per side with gun-drilled axles. I put 3.5 qt. in and still didn't feel lube with my finger at fill plug then put in the rest of lube and still don't feel lube. I have 4 qt. in there now. Is this o.k. or should I drain a 1/2 qt. I always heard to put in 3.5 qt.:confusd:
Old 05-11-2009, 08:15 PM
wrd1972's Avatar
Sounds like a lot.
Old 05-12-2009, 08:19 PM
SLP Firehawk's Avatar
yes i had 3.5 and it still came out the vent
Old 05-17-2009, 11:08 AM
It's not coming out of the vent. Anyone else? I'm doing the 5x15 min. break-in on the gears and rearend now and will be changing out the fluid this week. I'll see how much fluid drains out.
Old 05-17-2009, 02:13 PM
T/A KID's Avatar
Your suppose to use a little over 3 quarts.
Old 05-18-2009, 08:51 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
the rearend will hold a little over 3 quarts. with the car level, fill the gear oil until it is at the bottom of the threads on the level plug on the drivers side of the 9 inch center section case.
Old 05-20-2009, 03:23 PM
****, I didn't even know about the level plug. Thanks again Eric,you the MAN!!!
Quick Reply: Is 4 qt. lube too much for MWC FAB 9???
