Moser 12 vent tube
Old 05-17-2009, 01:51 PM
ElkySS's Avatar
Default Moser 12 vent tube
i have oil leaking out of mine and dont have any idea as to what do do about a breather. what did you guys do?
Old 05-17-2009, 02:58 PM
omcar's Avatar
I actually reamed my 10 bolt vent tube out with a very small drill bit and that allowed it to breathe.
Old 05-17-2009, 05:29 PM
ElkySS's Avatar
on the moser 12 the vent tube is relocated to the left axle tube. its not a normal breather. more like a barbed fitting to put a rubber tube on for a remote vent or something
Old 05-17-2009, 08:57 PM
silverLSWON's Avatar
you have to run a piece of hose (3/8) i think, from the breather and up near the gas tank. find a good place and zip tie it. also make sure you have the right amount of gear oil in the housing. if you have to much even just a little extra, it will vent out the breather hose.
Old 05-17-2009, 09:44 PM
ElkySS's Avatar
just a hose? not breather on it or anything?
Old 05-18-2009, 04:54 AM
EPP
EPP's Avatar
Correct, just a hose. Bob
Old 05-19-2009, 09:34 AM
ElkySS's Avatar
well the vent tube is broke off and i need to replace it. anyone have a part number?
Old 05-19-2009, 09:47 AM
EPP
EPP's Avatar
Question
You mean the pipe fitting is broken off? Bob
Old 05-19-2009, 09:57 AM
2002_Z28_Six_Speed's Avatar
yup it is pretty retarded that they did that and put it right in the middle of the tube. good thinking.
i wish they wouldn't of tapped it and put it there.
Old 05-19-2009, 11:03 AM
ElkySS's Avatar
yup. when i bought it rolled around in thew back of the truck and broke it off. (i bought it used)
Old 05-19-2009, 11:27 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Re-tap, and put in a barbed fitting (brass), get some rubber hose and a worm clamp as well as some zip ties, it just need to be higher then the hole.
Old 05-21-2009, 02:09 PM
99monguse's Avatar
I had this issue to...what type of fluid did you use and additive for your first fluid change OR what should we be using if it has a posi with 33 spline axle
Quick Reply: Moser 12 vent tube
