Housing, complete center section, what else...
Old 05-19-2009, 11:58 PM
Restricted User
1BAD_LS1's Avatar
Default Housing, complete center section, what else...
so if i buy a housing axle package and a complete center section is this ALL i need?
Housing axle package around $1000
complete center section around $500-$1200
seems like thats all i would need.... im going crazy i want to get my car going....
Old 05-20-2009, 01:15 AM
Nabdrill's Avatar
Gear oil
Third member gasket (if you don't buy the two together)
Old 05-20-2009, 10:15 AM
Restricted User
1BAD_LS1's Avatar
lol ok. im am debating building one instead of trying to buy a used one with my $1700
Old 05-21-2009, 11:29 AM
Restricted User
1BAD_LS1's Avatar
put together a rear for $1565 shipped thanks.
Old 05-23-2009, 12:18 AM
hoseman1553's Avatar
where did you find your setup?
Old 05-23-2009, 12:52 AM
LS1Silverado05's Avatar
Yep you are right.... That center section is certainly the big money changing factor...all depends what kind of center you get and what you put in it...
Old 05-25-2009, 10:16 AM
Nabdrill's Avatar
Take my advice!!!
If your 9" doesn't already have the fill cap on the back and the drain plug on the bottom then get those installed before you install the rear in your car. Filling thru the 3/8 plug on the side of the diff is a huge PITA.
Old 05-25-2009, 02:50 PM
Originally Posted by Nabdrill
Take my advice!!!
Sound advice..
Old 05-26-2009, 09:27 AM
Restricted User
1BAD_LS1's Avatar
yep it has the fill and drain plugs installed... makes life a little easier lol
