Midwest Susp setup
Old 05-23-2009, 12:11 PM
03 BUSA's Avatar
Default Midwest Susp setup
Right now I have the midwest fab 9 inch with stock lcas on a lowered car in the 2nd from the bottom. I will be getting some rod ended adjustable ones this week. I may keep the lowering springs in the rear or I may put the stockers back in just the rear. What hole should I put the LCAs in for either spring setup? It is an M6 car. Thanks guys. Also, what are your opinions on the Midwest LCAs compared to say a BMR setup??
Old 05-23-2009, 03:30 PM
03 BUSA's Avatar
Also, what is Eric's price on those LCAs?
Old 05-24-2009, 05:38 PM
03 BUSA's Avatar
Anybody?
Old 05-27-2009, 11:13 PM
Slvr00Bird's Avatar
Not 100% sure where to put them on your application, but when I talked to him on the phone, he said that the top two holes were probably all I could get my LCA's in (mine are lakewood, non-adjustable)... He said the very top hole was stock setting..
Old 05-28-2009, 03:46 PM
SS1875's Avatar
Mine are in the lowest position....stock springs (hose mod) and MWC adjustable LCA''s. Not sure on pricing since I bought everything together and he gives you a break on stuff(the more you buy).
Old 05-28-2009, 08:41 PM
Bad30th's Avatar
Mine are 2nd from bottom, non-adjustable BMR LCAs.
Rob (Bad30th)
Old 05-28-2009, 08:50 PM
RENE'S RAGE's Avatar
I just ordered his chromemoly double-adjustable rod-ended lca's. Give Eric a call on the price, you want find any lca better in quality and pricing.
