slip yoke rust...
Old 06-09-2009, 01:09 PM
checkbit's Avatar
Default slip yoke rust...
i little while back i got an aluminum driveshaft to replace the stock steel. the driveshaft has been sitting and the slip yoke has gathered, what looks like, a healthy coat of surface rust. should i attempt removing the rust? or should i just get a new slip yoke? (if so, anyone recommend where?) i am getting new universal joints, so the yoke has to come off, anyway.
Old 06-09-2009, 03:57 PM
Viper's Avatar
A buddy just had his cleaned up at NAPA for $30. Looks new again and they painted it.
Old 06-10-2009, 04:48 PM
01ssreda4's Avatar
i would try a scotchbrite pad and once you can see clean metal underneath the rust see if its pitted. If the metal isn't pitted then it should be fine. The seal only runs in a small portion of the slick part so even some pitting still may be ok. If it is pitted i would buy a new one simply bc i have fought tailshaft leaks before replacing seals till i was blue in the face and i wouldn't chance it simply bc of the potential aggravation.
Quick Reply: slip yoke rust...
