Can i put a 3:42 in my 98z with 2:73's?
Is it possible to run a 3:42 in my 10 bolt thats currently in the car with 2:73? If so what all is needed and what company for the gear do you recommend.
thanks,
Elliott
thanks,
Elliott
From what I understand the 2.73 rear has a 2 series carrier while the 3.42 rears are 3 series. You can order thick cut 3.42 gears that are supposed to work with 2 series.
What I found to be cheapest was to just buy a used 10 bolt with 3.42s already in it. All I did was swap the rears out. Plus if I break the 10 bolt, I've got a complete 2.73 backup to throw in it.
MP GM7.5-342T Thick Ring and Pinion
MK GM7.5 Master Kit
Let me know if we can help.
Jeff
www.jawsgear.com
MK GM7.5 Master Kit
Jeff
MK GM7.5 Master Kit
Jeff
I assume the carrier in my vette is the same as ls1 fbody with the same 2.73's. For the same price I would rather have 3.73 over 3.42
i have heard that once the gears wear in then if they are swapped to another car and dont mesh exactly the same it usually doesnt turn out well. I have never installed used gears though.
