Moser 9"-Sway bar mounts - LS1TECH
Thread Tools Search this Thread
Old 07-01-2009, 09:48 AM   #1
11secLS1's Avatar
Default Moser 9"-Sway bar mounts
All-
I have a moser 9 in with the BMR X-treme sway bar mounts welded on. I have decided that I would like to run a stock style sway bar. Can someone tell me what is different about the BMR style mounts? Is it just the hole spacing.
I am looking at running the Spohn 1" rear sway bar.
Thanks
11secLS1 is offline   Reply With Quote
Old 07-01-2009, 10:46 AM   #2
LS1Tech Premium Sponsor
BMR Tech2's Avatar
The spacing(distance apart) of the brackets should be ok you might have to drill some new holes for the sway bar mounts to bolt to.
BMR Tech2 is offline   Reply With Quote
Old 07-01-2009, 12:47 PM   #3
11secLS1's Avatar
Great, thanks!
Tags
9, bar, brackets, moser, sway
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
