What driveshaft size? QP 9" housing and 6spd
Old 07-08-2009, 03:29 PM
Ironxcross's Avatar
Default What driveshaft size? QP 9" housing and 6spd
I need to know the driveshaft length required so I can buy a driveshaft that would be exact fit for my set up.
Old 07-08-2009, 03:37 PM
Intercooler2's Avatar
General rule is 1" longer. In my case I ordered a longer pinion yoke and used the stock length Strange DS I already had. More than one way to do it but if you are ordering new may want to just measure when it is in.
Old 07-08-2009, 03:40 PM
Ironxcross's Avatar
Well I'm trying to do this all in one shot because it requires a different U- joint and I'm looking to replace the other one anyway. What is the length on the stock driveshaft then?
Old 07-08-2009, 03:42 PM
Mikey 97Z M6's Avatar
My Chromoly Strange shaft is 41-5/8" long with my QP rearend. It fits but only has about 3/4" of slide travel before it bottoms out on the tranny yoke. Personally I'd like a bit more slide travel so if I ever ordered another one, I'd probably go with a 41-3/8". With the current DS, it just barely clears the rearend yoke when removing the DS, that's why I'd like another 1/4" of slide movement.
FWIW, I have a T56 with stock length LCA's and LCA relocation brackets installed.
Mike
Old 07-08-2009, 03:48 PM
1" longer would be way too much for a QP rearend. Stock shaft is around 41".
Mike
Old 07-09-2009, 01:40 AM
Ironxcross's Avatar
Alright, thanks for the help Mike, I'm going to move on the size you suggested, the 41 3/8". I know the stock shaft works with the 9" but its a little short so adding some to it doesn't hurt.
