drive shaft 12 bolt --> 10 bolt
I am demodding my car to sell the car and parts separately. I already removed the Moser 12 bolt and replaced it with a used 10 bolt. The drive shaft is obviously different.
What's the cheapest way to make it work? Change the U joint on the rear or just buy a used stock drive shaft? It seems a used driveshaft is the easiest and cheapest?
I have an aftermarket shaft that fit the Moser I took out. I have put a stock rear back in it. I'll probably just look for a stock shaft so I can sell the other with the Moser.
Been researching this and I'm not sure it's the OEM shaft. The diameter is larger on both sides of the u joint. I looked up stock u joints and from what I can tell they are the same on both sides.
I'll probably just get a used stock shaft and sell the other with the Moser.
Thanks for the reply.
