3.42's Or 3.73's???
3.42's Or 3.73's???
Ok Soo Im Loking To Swap Rear-ends This Winter If Money Keeps Flowin' Like It Is.... I'm Lookin To Just Do A 12 Bolt Moser W/33 Spline Axels.. Ima Not Sure What Gear Ratio I Want To Go With.. Im Not To Worried About Gas Milage Just Lookin For Best 1/4 Times Really.. Already Got A Yank 3200 ss Converter... Idk If That Makes A Difference On What Gear Ratio I Shoul dGo With Or Not... Any Help Would Be Nice..
Thanks
-Dan
Thanks
-Dan
Well I don't really have any info on your car except that it has a 3200 stall. That at least tells me that it is an auto 3 speed or 4 so I would recommend the 3.73 normally but that also depends on what size tire your running on. How about you fill us in on some of the cars current setup and supporting mods done to it. I checked your garage but there are no vehicles listed in there.
Its An A4.. Right Now Ima Running Stock 245/505R16's Nittio Drag Radials. Pace Setter Long Tubes, Off Road Y-Pipe, Slp Loud Mouth 2, Ls6 Intake, Workin On Gettin Shift Kit And Deep Pan Installed Within The Next Week.. In The Feature Will Be Running Somthing Around The Same Height But Wider.. And Will Be Adding Control Arms Pan Hard Par Toqure Arm And Such When Doing Rear End Swap..
