Too much backlash??
Too much backlash??
A friend of mine came over to help me put in my new clutch yesterday and before we removed the driveshaft, he told me it had too much backlash. He estimated that it moved about .25 inches. He asked me if i had an after market rear end, and i told him no... i had a set of 4.10 gears put in may of last year (about 4000 miles ago). He said I should probably take it back to the guy that did it. I feel it would be very rude to take it back to the guy that did it because it was done at his house and i hardly know him. The car drives fine, but should i be really concerned about this? How much backlash should I have?
^^^thats true, this could be done easily with the cover off and a $10 dial indicator. But your friend may be correct, the driveshaft should turn a little back and forth but not much at all.
If your friend was just twisting the driveshaft back and forth, that's not a very good way to tell if your gears have too much bl. There could be slop in the ujoints. Plus, you can't really tell when the pinion gear contacts the ring gear without a dial indicator as mentioned before.
Mike
