Tackling 9" Install-Any suggestions to make installation easier?
the car 02 SS M6
ordering a 9" this week and plan to install it myself to save money. are there any issues you guys that have installed one before have ran into i should be aware of? any problems with parking break reconnection, brake lines or anything? any suggestions will be greatly appreaciated! thanks
No different than any other rearend.
Pretty much the reverse of stock... You can use 3" exhaust clamps from AutoZone for the sway bar... zip ties to hold down the brake lines...
I've heard that the rear of the 9" may bang into the floorpan if the car is lowered (or, sometimes, even at stock height). The recommended fix is to bang that area of floorpan a bit out of the way with a pry bar or big hammer. Couldn't find that tip on EPP's link, but I'm sure Bob will concur.
Other than that, just normal stuff. Follow the recommended break-in procedure, change the gear oil after the first 500-1000 miles, etc.
FWI: The Moser M9 (fabricated rear) http://www.exoticperformanceplus.com...html?item=1324 is designed totally different, and will not rub even on lowered cars. Bob
