timkin bearings for moser 12?
i am pretty much rebuilding my entire moser 12 bolt. i heard timkin bearing are what i should use to put this back together. my question is if anyone knows who sells a rebuild kit (carrier bearings, pinion bearings, pinion seal, shims, etc) that comes with timkin bearings. if not, does anyone know the parts numbers and ware i can get them at.
I know this might sound a bit basic, but since no one else has responded yet, I'll chime in.
Have you tried Moser? It looks like they use Timken bearings in the rebuild kits for their rear ends: http://moserengineering.com/Pages/Se...setupkits.html
You could try giving them a call & asking what part numbers they use for the bearings in their 12-bolts. I know AutoZone sells Timken bearings at decent prices, but they probably won't be able to find one for your 12-bolt. If you had the part number for the bearing, I'm sure they'll be able to look it up, though.
