Add me to the list of ppl in love with 4.10's
I bought a Timkin bearing kit, outer wheel bearings and seals, a TA Performance rear end girdle, and some GM 4.10's. And like most, I won't have it any other way from now on. I did a lot of research on peoples opinions of 4.10's and decided to go that direction. I couldn't be any happier! I know it puts a lot of strain on the 10 bolt but my car is the 3rd f-body to be in our immediate family and we made the other two 10 bolts last over 160,000 miles. My car has 92,xxx on it right now so it had a ton of life left but I figured I'd knock everything out while I was in there. I had TDP do all the work and everything is perfect and quiet. Just thought I'd share some more positive feedback.
that's what i hear.. our other 2 were m6's and seemed to do good. the car almost never sees the track. and the once in a blue moon that it does, it's on street tires and only make a couple passes. and i dont even dump the clutch. but hey, if it breaks ill just buy another one
i just got done installing my rear gears....thanks to scramblerman...6 hours ago and i agree, i dont know how i got along with out them...kinda cool took almost 9 hours but there is no whine what so ever...
well i just finished out my 1st tank of gas and compared it to my last. both tanks were about 80% freeway. got 2 mpg's less after the 4.10 install...150% worth it imo
can someone give a parts list with prices ? What else should I do while Im in there? cover? posi ? etc..
My car is strickly a street car and been thinking about adding 410 gears until it breaks. Been reluctant for awhile because I was afraid my rear end was going to just sanp with my ad-ons. So far it hasnt given me any trouble at all.
i did the gears, motive 189.00. raytech gear install kit 89.00, two thingys of 80w90w oil and one 8oz tube of gm gear oil addative....stops whine. and i replaced my outer axel bearings cus they were bad. total was like 250ish...but had a good buddy help with the install...but so far soooooooooo worth it...
$154.95 - TA Performance Rear End Girdle
$23.00 - ARP Bearing Stud Kit
$119.00 - Timken Master Install Bearing Kit
$50.00 - GM 4.10 Gears (an absolute steal at that price. don't expect to find GM gears for that)
$28.95 - 3 Quarts of Lucas Oil 75w-90 Gear Oil (only needed two)
$6.00 - GM Limited-Slip Rear End Additive (that's with employee discount)
$225 - Texas Drivetrain Performance Labor for Complete Installation
TOTAL: $606.90 + any shipping charges and taxes
Again, you can get the parts cheaper used, and you can install yourself. I didn't mess with it bc TDP warranties the work they do and they've set up 1,000+ 7.5" 10 bolts...
