??? about Ratech Kit and Tune
Old 08-01-2009, 12:33 PM
Yahelou's Avatar
Default ??? about Ratech Kit and Tune
I plan on buying the thunder racing package: http://www.thunderracing.com/catalog...&vid=3&pcid=68 with the strange 2 series 3.73s and the deluxe ratech kit. I have read some ppl seem to get the wrong parts for these kits. how can I check to see if i get the right parts??
the car has been dyno tuned, and i dont plan on putting it back on the dyno or messin that tune up. i know the speedo has to be recalibrated, but do the shift points also have to be changed??
Old 08-01-2009, 02:17 PM
Yahelou's Avatar
anybody??
Old 08-01-2009, 06:52 PM
Yahelou's Avatar
nobody??
Old 08-02-2009, 01:27 AM
01ssreda4's Avatar
i dont understand what parts you are refering to exactly. They make a variation 10 bolt kit that is for late 70s model 10 bolt where the biggest pinion bearing is smaller and wont fit our housing, but no other changes that i know of. Pinion seals changed in mid 01 year so unless your car is an 01 or 02 nothing to worry about there as the ratech kits come with the earlier style seal.
Old 08-02-2009, 01:34 AM
jetlag's Avatar
I mentioned to him about a Motive kit not having the right seal for my car. I guess I should have added it was 01-02..hehe
Old 08-02-2009, 09:43 AM
Yahelou's Avatar
i was reading on here that some ppl get the wrong parts. I just wanted to know a way to check all the parts in the ratech kit to make sure they are right for my car.
these are part numbers straight off their site http://www.ratechmfg.com/gmstandard.htm, i guess i would use those part numbers to compare to what i got from them.
Old 08-02-2009, 01:42 PM
Thyme_CA's Avatar
I ordered that kit and everything worked fine
Old 08-02-2009, 03:05 PM
01ssreda4's Avatar
basically all ten bolts are exactly the same with the exception of late 70s models and that seemed to be only the first few years. the kit for our cars is a very common kit that ratech prolly makes tons of. I have ordered bunches of ratech kits and all parts were perfect.
Old 08-02-2009, 07:52 PM
Yahelou's Avatar
oh ok, that makes me feel better. i guess some ppl had bad luck. thanks for the help.
anybody know anything about the having to change shift points?
Old 08-03-2009, 09:18 AM
Moderator
jimmyblue's Avatar
If you don't change gear ratio then you don't have
to change shiftpoints (other than, stock settings
are lousy for part throttle street driving or modded
WOT). With 3.73s, yeah, at least a ratio scaling
(the software I use, will auto-scale from the ratios
if you let it and hit all the affected tables for you).
I have Ratech master rebuild kit parts throughout
in mine, with the 3.42/T-2R swap, including solid
spacer. No complaints, maybe 20Kmiles since and
not a peep. You might want to shop the separate
prices, sometimes people think they deserve a fat
check just for bundling. And make sure you like the
completeness of the wear-parts kit, you have a
(hopefully) one time opportunity to renew the guts
so make the most of it.
Old 08-03-2009, 07:57 PM
Yahelou's Avatar
Thanks for the help.
