any issues for 4.10 on slow speed in the street ?
i just got the 4.10 on
and in low speed i get vibration.. while am in the 1st gear
is that normal ?
is that normal ?
i dont think so i checked that and its okay
dunno whats wrong
someone told me its normal .. many mods and a very close ratio cuase this .. !?
my car made 375 Hp
is that too much power for the street ?
is that matter ?
dunno whats wrong
my car made 375 Hp
is that matter ?
LOL too much power for the street? no. are the gears whining or howling? how are your driveshaft ujoints? that would cause your vibration. try rotating your driveshaft 180 degrees if nothing else works.
The reason I had my gears changed is because the pinion bearing was bad (labor has to be done anyways right?). With a bad pinion bearing, there was a "speed sensitive" howl that started at 5mph and eventually turned into more of a whistle at around 35+. Did you reuse your original bearings?
