Pinion Bearing/Race Revmocal Questions
Had a shop rebuild my rearend with all new bearings and seals. 3 months later and it's roaring again.
What is the EASIEST, and LEAST HARMFUL way to remove/install new races? I know a mallet will help with the removal, but I want it done right.
Working on a series III 7.5"...
To get to the pinion races the entire rear end has to be taken apart. Driveshaft, wheels, brakes, cover, c clips, axles, carrier, pinion. In that order of course. Then when the center chunk is completely empty you beat the old races out and you need a bearing installer to push the new ones in without damaging them. (some people may beat on old races to push the new ones in, I dont) Then reassemble.
I just use a really long flat tipped punch, just like you'd use with wheel bearings. Never had a bearing failure in about 40 yrs. due to damage on installation.
Recently I flushed my entire brake system, I believe it took about a full jug of brake fluid. The **** that came out of there looked like used motor oil. Since you broke the brake system loose, it would be a great excuse to do that. Start with the furthest from the master and work closer. So BR, BL, then FR then FL last. I flushed the reservior when doing the first one the back right. It took flushing it 2 to 3 complete times to get the fluid clean in it. I emptied it into a small container so I could see it as it got clearer. I had a friend push the brakes while I bled.
Not saying its not possible, I bought a very nice (for the price) bearing installer set with multiple (10) size inserts at HF for only like $25. I like having the correct tools whenever possible.
