T/A rear whine!
T/A rear whine!
I bought an abused '95 T/A a few months back and I'm fixing all the problems with it so I can enjoy the car reliably after I'm done. I'm driving the car occasionally to run it and keep the battery charged and such. So, I have a few questions: 1) The rear is whining like the ring/pinion isn't set up right. Is there a way to set it up correctly now to eliminate the whine or is it likely already damaged to the extent of needing new gears and rebuild? I ask because I don't really want to have to pay someone to do a complete rearend rebuild if I don't have to. I am mechanically inclined enough to get a few precision tools and do so if need be to avoid paying for labor. 2) Is there somewhere I can find comprehensive/detailed instructions to do so? 3) What are the parts needed to JUST replace/ setup the ring and pinion? Thanks for reading guys!
-SS
-SS
If it whines all the time you may need some gears, if it whines only on accel or decel only then you could prolly use the gears you have. Some excellent write-ups: I would buy a master/deluxe install kit and replace everything I could.
http://www.vernco.com/rearaxle5/index.htm
http://www.jawsgear.com/tech_kits.php
http://www.greenfries.info/rear_gear.htm
http://www.keliente.com/gears1.htm
