torsen and fluid?
Old 08-27-2009, 07:44 PM
mook99ta's Avatar
Default torsen and fluid?
Do I need to add Limited Slip additive with a torsen rear or is that just with the auburn's?
Old 08-27-2009, 08:43 PM
WYATT318MOPAR's Avatar
No real need for the additive since it has no clutches, some people think it makes the rears quieter anyways. Good synthetic fluid should be just fine.
Old 08-27-2009, 09:22 PM
rednari's Avatar
Any good grade of conventional gear oil will do.
Old 08-27-2009, 09:26 PM
01ssreda4's Avatar
syn has the additive already in it. But with torsens you dont need it. You can pretty much run any gear oil you want with them as long as its 75-90 weight.
Old 08-28-2009, 10:54 PM
Ls1guy98's Avatar
what people don't understand is friction modifier ADDS friction so the clutches in a clutch type limited slip can grab , do not put friction modifier in a zexel torsen car!
Old 09-05-2009, 08:42 PM
crainholio's Avatar
Mine has liked RedLine Heavy Shockproof gear lube since it was installed back in 2001-2 timeframe. It's thick, tough, and keeps the Torsen gears well lubed.
Old 09-06-2009, 10:52 AM
mook99ta's Avatar
Thanks that is what I went with
Quick Reply: torsen and fluid?
