Axle spline question
Old 11-28-2003, 10:01 PM
STF Veteran
99-LS1-SS's Avatar
Default Axle spline question
Can someone explain the differences in the number of axle splines? I understand that 33 is more than 34. I want to know which is stronger and why.
Old 11-28-2003, 11:07 PM
SMOKIN01TA's Avatar
i believe you can get up to 35 but i have the 33 the bigger the number the stronger, i guess the more splines the greater pressure they will take before they will twist. 33 is more that enough for a 8 sec. car
Old 11-29-2003, 07:35 AM
STF Veteran
99-LS1-SS's Avatar
Why would they offer different spline numbers if one isn't as strong as another? Is there a drawback to the stronger spline?
Old 11-29-2003, 02:13 PM
SMOKIN01TA's Avatar
same reason they offer a variety in everything else, you pay more for the higher quality. also the more splines i was told the noisier the rear end will be. and if you dont want a 8 sec car than you would be fine with 30 or 31 spline axles. they are cheaper and quieter and dont come with a free replacement waranty if you break them but if you not going to have the power to break them and you want less noise go with them.
Old 11-29-2003, 08:53 PM
STF Veteran
99-LS1-SS's Avatar
Thanks
