4.56 gears yes or no
Old 09-14-2009, 07:18 PM
Big Red Z28's Avatar
Default 4.56 gears yes or no
Any one running 4.56 gears? I have trick flow heads custom cam, Fast 92, lt and borla exhaust, ud pulley, drag radials, t-56 tranny with spec stage 3 clutch, and 4.10 gears. I dont daily drive the car and if i do it is in town not for long distance, more of a weekend street racing for the fun of it no winter driving i dont take it to the track or do high rpm clutch drops. 2001 Z28. This may be a stupid question as i cant find much info on this so please educate me on this if i'm being stupid thanks.
Old 09-14-2009, 07:26 PM
1nastyss's Avatar
i just went from 4.11 gears in a true trac to a fully spooled 4.56 gear setup, i wish i would have done it sooner, awesome...its not bad on the street at all, its mt DD
Old 09-14-2009, 07:56 PM
02SOMWS6's Avatar
to get the most out of a set of 4.56 gears your going to need a 28" tire. To play around on the street is fine but if your going to get serious and want the most out of the car N/A at the track 4.56 gears with a 28" tire is the steepest you can go without running out of gear. You would not make a full pass on spray without running out of gear. If 28" tires are out of the question than a set of 4.33 with 26" tires will act like a set of 4.56 gears with 28" tires. And down the road if you wanted to spray with the 4.33 you would then have to switch to a 28" tire. So in short
26" tire go with 4.33 gears
28" tire go with 4.56 gears
either way on the street your gonna be peddeling the car to try and get traction if you were to try and race someone. Better off staying with the 4.11 and getting a 26" slick to play on the street if your not serious about going to the track
Old 09-14-2009, 08:06 PM
NSSANE02's Avatar
With your mods I would stick with the 4.10's. I have 4.11's and a 28" tire and I'll run out of gear well before the 1/4 on the bottle. Even if you don't go to the track, 130 just comes way too quick.
Old 09-14-2009, 08:11 PM
1nastyss's Avatar
reason i went 4.56's was because i am running an NA setup and dont plan on spraying, i plan on running a 28x 10.5 MT
Old 09-14-2009, 08:20 PM
NSSANE02's Avatar
^^^ What is your limiter at?
Old 09-14-2009, 08:23 PM
Thanks for all the info, still learning i failed to mention the tire size. using nitto 17/275/40 so the tire should be approx. 26", currently no spray for now just lookin for extra fun to drive on street without loosing out to same set up with 4.10's. I might be pressing the question so thanks to all who replied.
Old 09-14-2009, 08:32 PM
gyrene2003's Avatar
So a 4.30 is still good to run on a 26" tire? I was thinking about a steeper gear when I do the 9" swap. Is all this info strictly for and relating to 6sp guys?
Old 09-14-2009, 08:38 PM
NSSANE02's Avatar
Use this and find out for yourself. http://f-body.org/gears/
Old 09-14-2009, 08:59 PM
02SOMWS6's Avatar
on the street even with nitto's your going to blow the tires off now with the 4.10 gears. Your best bet is to put money into the suspension to hook better or any other engine mod you may have missed( e/water pump, etc.) or drop some weight in the car. On the street anything higher then 4.10 is just a waste. My guess is you don't hook now and that will only get worse with a steeper gear. Stay with the 4.10 gears and get a stickier tire for friday and saturday night
Old 09-15-2009, 10:49 AM
Troy's Avatar
I have a very similiar setup to you and currently use a 4.10 gear with a 26" tire and do not cross the line near my rev limiter (6600) which is also near where my peak power is. I'm moving up to a 28" tire and 4.56 gears to get closer to crossing the line at my naturally aspirated peak power. use the gearing calculator as someone said to figure out what RPM you want to cross at and then back into what gear/tire you need...
Old 09-15-2009, 11:11 AM
getusum's Avatar
I went from a tru crap and 4.11's to a spool and 4.56's.....hard for me to blow the tires off...I've got everything BMR has to offer though....I run a 28'' tire and I don't have to launch as high as I did with the 4.11's....I used to bog with the 4.11's leaving at 7200..Now I leave around 6000....My limiter is at 7200
Old 10-13-2010, 12:14 PM
BFarrier's Avatar
my 4.56 come in tommorrow!! i will let you know how i like them
Old 10-13-2010, 07:12 PM
Zmg00camaross's Avatar
Love my 4.56s drive on the street with QTP hoosiers 28s. If you want to play N/A i would go with the 4.56s no doubt
Quick Reply: 4.56 gears yes or no
