Spool for a 9"
Old 09-22-2009, 07:15 PM
the_merv's Avatar
Default Spool for a 9"
I got ahold of a Nodular Iron Case and I'm building that into my Track Rear. I have a set of 3.89's for it, what would be a great Spool for it?
I have 31 Spline Axles..
Old 09-22-2009, 07:33 PM
staticz2229's Avatar
Here is a spool that I would recommend on eBay:
http://cgi.ebay.com/ebaymotors/ws/eB...m=220483625206
Thanks,
BRYDON
641-751-8060
Old 09-23-2009, 08:37 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,090 Likes on 718 Posts
If you are interested in used stuff I think I have a used 31 spline spool at the house. Just email me at john@motorsports-media.com and I'll check.
For new I'd get Moser or Strange probably.
Old 09-23-2009, 01:30 PM
the_merv's Avatar
Cool, thanks. What kind is the one you have?
Old 09-23-2009, 02:01 PM
StreetSilverado's Avatar
I'm running a strange spool in my 9" with 31 splines and it works great, no problems at all with it.
Old 09-23-2009, 03:13 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
Double check your bore size on that case. It should be 3.062 for a 31 spline spool or differential.
Scott @ DLS
Old 09-23-2009, 06:12 PM
the_merv's Avatar
Are you talking about the Pinion Support Bearing size?
Old 09-24-2009, 08:28 AM
LS1Tech Sponsor
Differential bore size in the case or center section.
Old 09-24-2009, 08:47 AM
the_merv's Avatar
I don't have it with me at the moment..I know that the Screw-in Adjusters are the same size as the stock 9" Center that I got with it.
I got two compete 9" Centers off of a kid on Craigslist for $65, one was the Nodular one so I kept that, the other was stock so I kept all the bolts and stuff and scrapped it.
Old 09-26-2009, 09:40 AM
The 31 spline spool that I linked you to on eBay will fit both a 2.89" or 3.06" case, but not a 3.25" case. If you have a factory center section case you are good to go, as they did not make a factory 3.25" case. If you have an aftermarket center section case you need to make sure that it is either a 2.89" or a 3.06" case.
BRYDON
Old 09-26-2009, 10:05 AM
the_merv's Avatar
This one is a stock Ford part..
