Can a built 10 bolt hold 800RWHP on the street?
Well I currently have a Moser 12 bolt and the car will not be seeing the track much longer so I am probably going to ditch it. Do you guys know if a built 10 bold, i.e. HD posi, Moser Axles, and a T/A cover will hold up to 800RWHP on the street? It wouldn't be from a dig, but generally just roll stuff, 30MPH type runs. What do you guys think?
are you asking this to be funny or are you serious?
lets see how should i put this ummmmmmmmmmm.................... hell no id keep the 12 bolt
i wouldnt put any money in that stock pos 10 bolt just my .02
i would honestly keep the 12 Bolt, i fried my bearings several times, broke pinion gears and keep popin the seals in it, trust me i have had nothing but trouble with the built 10 bolt, i am actually savin up for a 12 bolt at the moment.
My car dynoed 368RWHP...........And POOF.......Broke the spider gears and one of the gears the axel goes into and i was not at the track when it broke.(Eaton Diff Stock 3:42 gears)
Johnny
I see where you're coming from with trying to go back to the 10 bolt but it's just too small. Even from a roll and with an automatic that thing is probably going to grenade.
I had a buddy with a "built" 10 bolt. Also have another one with a stock one. Both cars are bolt ons only. No cam,heads,etc.
When you build a 10 bolt your just moving the weak spot around. It seems the axles usually go first. He Broke the axle so he put in moser ones. Now the axles are strong but he broke the spider gears (eaton). If not the spider gears, twisting the pinion itself in two is probably next (4.10). Might be ok with stock gears.
Now my other friend just has a collection of stock axles. He breaks an axle he just swaps a new one in. Cheaper and can be done with the rear in the car easily. If your gonna do a 10 bolt at least look for a 2 series carrier one with a low gear ratio. Just my opinion
i wouldn't put a 7.5 10bolt under my nieces tricycle! even a built one! i sure as hell wouldn't waste money on one! 7.5 10bolts are good for one thing A BIG PAPERWEIGHT!!!! i have broken 3 of them. i now run a 9"
You might try a new set of gears in your 12 bolt, you might just have a noisy set of gears. You can have two fairly identical sets of gears, and installed with same clearances, one can end up being loud once installed, and the other set can end up being quiet. Bob
I can trade my 10bolts for your 12bolts
honestly, I'm on my 3rd rear end(and its gonna blow soon, I can tell) and its annoying to always destroy this rear end. And I dont like the idea of spending 4K on parts and not getting one pony more at the wheels. It will be the very last mod I'll do.
800rwhp on a 10 bolt? Come on seriously dude. You're smarter than that. My 10 yr old brother can figure that out. I wouldnt push more than 400rwhp on a 10 bolt. Get the Dana 60 or Mark williams 11'. Good luck
