rearend noise
rearend noise
The rear end noiseOkay so I was just driving normally (something I should never do because something always goes wrong). And this noise appeared.I changed out the torque arm for a UMI but it is the same exact noise. Anyone with ideas on how to solve this problem please help.
looks and sounds like the rear most portion of your driveshaft is barely knocking against your exhaust. i'd grab a rag, wrap it around your exhaust pipe close to there, and pull it down a little to get it out of the way while the driveshaft is turning.
It seems to me that's a blunt sound. I suspect that the driveshaft is hitting the torque arm at some point. It looks like in the video that the corner of the shaft could be slightly knocking. I would remove shaft and inspect both the front and rear of driveshaft.
If it is not the shaft, try looking at the pinion yoke. I think it maybe is hitting the torque arm.
