Remove the 10 bolt rear????
Old 10-16-2009, 08:37 AM
boola1341's Avatar
Default Remove the 10 bolt rear????
I'm attempting to remove the 10 bolt rear this weekend out of my camaro. I just wanted some advice and info on the type and size of tools I'll most likely need. Any good tips would also help. Should be getting the 12 bolt soon.
Old 10-16-2009, 07:31 PM
boola1341's Avatar
anyone???
Old 10-16-2009, 07:41 PM
danhr's Avatar
lift the back of the car by the pumpkin of the rear end, place jackstands on SFC's or wherever you want them at. Lower car onto jackstands, but leave the suspension under a load with the jack. Unbolt everything. Lower the jack again, and watch the rear come down.
18 mm, 21mm, 22mm.
Old 10-16-2009, 07:51 PM
litch2004's Avatar
just did mine a few weeks ago. It really isnt that hard. Just make sure you get all the tabs lifted up that hold the brake lines on or they might bend or even kink up.
Old 10-18-2009, 07:36 PM
boola1341's Avatar
Thanks for the help!!!!!!!!
Quick Reply: Remove the 10 bolt rear????
