What carrier unit comes with Moser 12 Bolt rears?
Old 12-06-2003, 07:50 PM
Fred99LS1's Avatar
Post What carrier unit comes with Moser 12 Bolt rears?
Guys, my 99 Z when I bought it had a Moser 12 Bolt rear. I'm curious what rear posi unit it most likely would have in it. Does Moser usually go with just one brand posi unit? Heck I'm not even positive what gears are in the back due to me buying the car from a dealer who got the car at auction. The odometer says 34,000 miles. The car is mint, Fred
Old 12-07-2003, 02:00 PM
AZLS1's Avatar
The most likely posi will be an Eaton.
Old 12-07-2003, 11:00 PM
SMOKIN01TA's Avatar
most likley the eaton. make sure you spedo is accurate and then check your rmps at 70 to figure out you gear ratio i run 1900 at 70 with 4.10s and 1400 with stock 3.42's so if its in the middle it 3.73's
