Pics of my Midwest Chassis 9"
Old 10-25-2009, 06:45 PM
cpd004's Avatar
Default Pics of my Midwest Chassis 9"
Hopefully I can finish this thing up soon and get it in the car. I still need to bend the brake lines a little better and mofiy the loop/torque arm mount as it won't fit next to my exhaust.
Old 10-25-2009, 06:52 PM
cpd004's Avatar
Let's see if this is bigger.
Old 10-26-2009, 02:39 AM
IWGF's Avatar
Sick. I can't wait to get mine...
Old 10-26-2009, 07:10 AM
wrd1972's Avatar
Be careful where you have that brake line run right under the top torque arm mount. I ran mine there too and I had to grind a flat spot on the jam nut to keep from damaging the brake line. Not a biggie, just a heads up.
Old 10-26-2009, 07:16 AM
No Juice's Avatar
More details on the rest of it? Looks like an aluminum Strange center
Old 10-26-2009, 05:02 PM
cpd004's Avatar
I have that in mind. I will make final adjustments when it's under the car.
It is. I have Strange SS axles with the aluminum center section. It's a 4 channel rear with stock brakes and Russel braided lines. It's killin' me to mod the front torque arm mount, but I have no choice. It looks great and the welds are very nice. It just won't fit with my exhaust. Whoever Eric uses for powder coating does an excellent job as well.
Old 10-27-2009, 12:56 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
I have 3 different crossmembers if the one you have wont work... or i can make you a custom if need be. didn't i show you the ones available?
Old 10-27-2009, 02:45 AM
robsquikz28's Avatar
That looks sick man
Old 10-27-2009, 07:16 AM
cpd004's Avatar
I didn't know know Eric. When I left, there was only this one there with my other stuff. If I would have known, I wouldn't have 'modded' this one.
It's OK..after some grinding, I think it'll be just fine. The only thing I have left to do is make a small dent in my exhaust and paint the spot where I ground down the crossmember. I also had to enlarge the bolt holes just slightly.
Old 10-28-2009, 07:58 PM
cpd004's Avatar
Well it's in and the brakes have been bled. I didn't have time to get it down and take it for a ride, but when I tried the wheels on the car (315's) they rubbed pretty badly. I can't imagine I'd need a spacer for this rear, correct? Again, this is with it in the air and no load in the suspension.
Old 10-28-2009, 08:41 PM
nnracing's Avatar
my 325s did that until i put the car on the ground
Old 10-28-2009, 09:10 PM
cpd004's Avatar
I was thinking the same thing...I'll have more time to do that tomorrow. Otherwise, everything fit like a glove.
I added Strano springs and UMI with a Bilstein for flavor back there.
Old 10-30-2009, 07:13 AM
cpd004's Avatar
Took it for a ride yesterday finally. Only went a few miles to get gas and back. No noise and everything seems ok. I nned to make 5 trips before I can see how it does on a launch.
Old 11-04-2009, 09:16 PM
cookba's Avatar
what read fluid are you using for it? what did Eric recommend?
Old 11-05-2009, 06:28 AM
cpd004's Avatar
Eric said any 80/90 would be fine as long as it isn't synthetic. He did suggest to stop at a Ford Dealer and get their anti-slip additive though. I bought 4 quarts of the 80/90 and the additive at my local Ford dealer for $24. Very inexpensive I thought. I read on another site that the Ford gear oil is excellent compared to the off brands you see at the auto parts stores and it is specifically made for Ford designed rear ends.
I've got about 60 miles on mine now and am going to lift the car up and go over every bolt to make sure everything is still as it should be. Otherwise, I finally got on it a little yesterday and it seems great. No gear noise at all. The Strano suspension is excellent as well. I;m not sure I'll be able to get to the track one more time this year. I'll try though.
Old 11-05-2009, 06:57 AM
No Juice's Avatar
Did you go with the Tru-Trac? What gears?
Old 11-05-2009, 10:56 AM
cpd004's Avatar
It's an aluminum posi unit by Strange with 3.70 gears. If I didn't plan on taking the car on Power Tour eventually, I would have gone steeper. This seems to be a good compromise.
Old 11-05-2009, 11:59 AM
CarsAddict's Avatar
Looks nice, maybe not that modernised looking but still, the performance I'm sure is great.
Old 11-05-2009, 01:40 PM
brians91formula's Avatar
Cant wait to get mine this Winter
Old 11-05-2009, 02:53 PM
SPEED#1's Avatar
now thats pretty
Quick Reply: Pics of my Midwest Chassis 9"
