my car has 2.73's, i want to put 3.73's.i have ?
Old 10-26-2009, 07:20 PM
craig h's Avatar
Default my car has 2.73's, i want to put 3.73's.i have ?
like the title says, i want to put 3.73 gears in my car. it's a 98 z28 m6 w/2.73's. which carrier do i have? which do i need? do i have to change the carrier? or can i use a ring gear spacer?
Old 10-26-2009, 07:29 PM
shtnfrds's Avatar
you have a 2 seires carrier and you can do 1 of three things.
1. you can buy thick gears for the 2 series carrier, i think strange sells them.
2. you can buy gears for a 3 series which are thinner, plus buy a ring gear spacer. it's cheaper to buy the thick gears by the way.
3. you can buy a new 3 seires carrier from any number of sponsers and the 3 seires gears for that carrier.
any of these will work.
Old 10-27-2009, 08:40 AM
redbird555's Avatar
Was your z ever swapped from an auto? Any m6 factory car should have GU6 on the door and thus have 3.42's in the back. Btw 4.10 is prolly a better gear for a manual because of the steep overdrive. 3.73 people usually use in autos.
Dan-
Old 10-27-2009, 09:03 AM
rob scott's Avatar
like redbird said, 4.10's are a better gear for the m6. Jaw gear's sells series 2 gears and their a sponser on here.
Old 10-27-2009, 09:48 PM
craig h's Avatar
my car did have 3.42's in it. they were switched 2 owners ago. i think my speedometer is off by about 10-15 mph. when my speedo reads 75 mph at 1800 rpm's, i'm flyin buy by other cars ,feels like i'm doin about 85-90. am i crazy or has anyone else experiaced this?
Old 10-27-2009, 10:20 PM
gold98Z28's Avatar
well, from the factory you had a 3 seriers. but in order to get 2.73's i ASSume they changed it to a 2 series. i dont know if they make 2.73's for a 3 series or not
Old 10-27-2009, 11:09 PM
TransAmatt99's Avatar
I think that the 3.73's are plenty and it will keep you from revving high in 6th. I have them and you will be turning 2k @ 80mph.
Old 10-28-2009, 09:53 AM
ND2RACE's Avatar
This man speaks the truth, and many places make the appropriate gears.
Yes a M6 should have come with 3.42s and a 3 series carrier, not sure why it doesn't have this but 2.73s cannot be installed on a 3 series. The whole reason for the difference in carriers is to make up for the difference in pinion size. A 2.73 pinion is huge so a 2 series carrier moves the ring gear away from the pinion center line, and a 3 series moves it closer. It's really pretty simple, for example a 4.56 pinion (biggest ratio that fits in a 10 bolt) is tiny and why it's prone to breaking. Some other bits of info to consider with such a small rear-end, not only does increasing the ratio multiply torque to the rear wheels, it makes the pinion smaller and weaker. I've seen quite a few broken pinions and all were from putting in bigger gears.
Personally I'd never go bigger then 3.73s in a 10-bolt, especially if you're making any power what so ever. These are also most of the reasons everybody upgrades from this worthless rear end in the first place.
Old 10-28-2009, 10:01 AM
gold98Z28's Avatar
oh i understand. ive built way to many of these little junk basterd. i just didnt know if by chance someone made a 2.73 for a 3series carrier. the ring gear would have to be awful thin but i think it could be possible, tho very highly unlikely
Old 10-28-2009, 10:11 AM
DAS1998's Avatar
Check Out Randy's Ring and Pinion
www.ringpinion.com
Quick Reply: my car has 2.73's, i want to put 3.73's.i have ?
