Gear swap in a AWD TBSS
Old 11-27-2009, 10:54 AM
RsSean's Avatar
Default Gear swap in a AWD TBSS
I was thinking about buying one and swapping out the gear for some gears that are more gas frienldy since it would DD.
The rear is easy to do, have done gear swap on them before. I am lost when it comes to the front diff. Are they the same gear set up as the rear, like 3:42's or do they come in different sizes.
Any help would be great
Sean
Old 11-27-2009, 01:51 PM
NC98Z's Avatar
If you have 3.42s in the rear then you have 3.42s in the front also if its stock.
Old 11-27-2009, 02:21 PM
fast's Avatar
don't all tbss have 410?
installing front should be pretty similair to rear, you just have cv shafts instead of internal axles
of the regular tb's I've sold in the past all had 373 or 410
Old 11-28-2009, 09:38 AM
RsSean's Avatar
I just did not know any thing about front axles on those vehicles.
Thanks
Quick Reply: Gear swap in a AWD TBSS
