rear end question
Old 11-28-2009, 09:32 PM
raidernation3017's Avatar
Default rear end question
will a 97 z28 rean end without traction control work in my 98 ss with traction control without any mods
Old 11-28-2009, 09:35 PM
Ls1N20's Avatar
Uhm, im pretty sure there are sensors on the rear ends.. not 100% tho
Old 11-28-2009, 10:01 PM
just wondering if the traction control matters
Old 11-28-2009, 11:11 PM
jetlag's Avatar
It will work if you don't care about losing ABS and traction control.
Rearends with Traction control (4 channel) have ABS sensors on each axle end. Rearends without traction control only have one ABS sensor on the differential.
Old 11-29-2009, 12:50 PM
thanks
Old 11-29-2009, 09:01 PM
1SweetSS's Avatar
Switch your backing plates and axles into the donor rear.
Old 12-05-2009, 11:49 AM
how about a rear that has drums is it easy to change drums to disk.. will all my parts fit on the drum rear. got a smoking deal on a drum rear
Old 12-06-2009, 02:46 AM
Blacklightning744's Avatar
also the axles one the traction control rearend have reluctor rings on the end of them.
Old 12-06-2009, 11:51 PM
Atomic02's Avatar
It will work but you're gonna have some abs and traction lights on...
